04-16-2015 08:31 AM
I am looking for a way to use external values (from a tdms) as x axis values in a graph.
Just like you do in excel where you select a column to use as the x axis values.
The first channel of the tdms holds the values of a counter. (xx.yy secs)
I cannot find a way to use these values as x axis reference.
Thanks in advance.
Solved! Go to Solution.
04-16-2015 08:36 AM - edited 04-16-2015 08:37 AM
Hi F.,
why do you use a SplitSignals Express function to index elements on a waveform array? (Get rid of ExpressVIs and DDT as much as possible…)
On your question: get the Y component of your waveforms and build a XY graph from them!
Like this:
04-16-2015 08:38 AM
You actually want to use an XY Graph. You use a Bundle to create a cluster. The first item is an array of the X values and the second item is an array of the Y values. This cluster then gets wired up to the XY Graph's terminal.
04-17-2015 01:48 AM
Thank you guys !
My search quest ended
