use event handler programmatically
Hello, I use the Labview 8.2.1 and I would like to ask something about event handler.
I have some buttons and I use an event handler to perform their tasks. The buttons are used only with the mouse and not programmatically.
Now, I want to use a button programmatically without pressing it. I didn't find how to do this, so I created a boolean variable and I added to the event handler of a button a second "Event Specifier" of that boolean variable with the event "value change".
I assumed that it would work, but it does not, that is, the event handler is not used when the value of the boolean variable changes.
How can I solve it?
Thank you in advance.
(2,906 Views)
Accepted by topic author nikosfs
Write to the Value(Sgnl) property node of the variable you want to change.  This will set off an event programatically.
22272iA53B1FB96387ADA6
- tbob
Inventor of the WORM Global
(2,905 Views)
