use binning
Hi all
I add binning in my program but after take one Image, have error. I work with apogee camera.
is there anyway to take image with binnig?
attach my file
Regards
(2,684 Views)
What error are you getting?  It is hard for someone to help debug your problem if you don't tell them what is wrong.
You can also eliminate the stacked sequence structures in your code.  It is just hiding code.  The error wire in your VI will determine the order of operation anyway.  Use Replace with Flat Sequence on each of your stacked sequences.  Then you will be able to remove the stacked sequence.
(2,674 Views)
sorry I am new in LabVIEW
I change my program whitout any sequence.
I mean about error, after runnig ,I can not take picture and nothing was happen!!
(2,666 Views)
and I also chang somthing but I see this error that attach it
(2,637 Views)
