usb to serial
I am using a device (power meter..Maestro)  that talks over a USB Cable.  I downloaded the usb drivers from the manufacturers website and can talk to the device using Hyperterminal.  When I try and use MAX or Basic Serial Read/Write.vi neither works.    The read field of the vi is blank.  Does VISA treat the USB as a serial interface??  Its showing up as COM 3.  I did put in all the correct parameters..BAUD, Stop BITs, parity..etc.
(3,756 Views)
Hi Mark,
did you also read the device's manual and did you set the EndOfLine char correctly in the VISA-Init call?
(3,751 Views)
It should act like a VISA Serial:Intr class.  Did you close the hyperterminal connection first?  You can't open two connections to a COM port.
"Should be" isn't "Is" -Jay
(3,748 Views)
Try adding termination characters to your writing command. In serial terminal these are added automatically but not in labVIEW. So, add CR and LF to your command.
(3,746 Views)
Yes, closed the Hyperterm  Past exp has told me you can't have to sessions open at the same time.
(3,732 Views)
Unless that is unique to Labview..the manual says I don't need the cr and line feed....but I'll give it a shot.
(3,730 Views)
Gentec also has LabVIEW drivers, which may make your task a bit easier:
http://www.gentec-eo.com/downloads
-AK2DM
(3,710 Views)
