usb raw multiple endpoints
I have a device with 2 different endpoint INs, using interrupt transfer.  How do I specified the endpoint number?  I'm using Labview 8.5.  The USB interrupt IN VI doesn't have a field to specified endpoint number.
Thanks in advance,
Sinh
(2,706 Views)
you can use USB Settings:Bulk-In Pipe
Right click on the property node and go to Select ClassISA/O SessionSB Raw.  Then you can left click on the word property and select USB SettingBulk In Pipe
(2,703 Views)
