usb 6002 practice
I am testing it now. I am not exactly sure how to use the hardware and software for this USB6002 and LabVIEW. I wired AO GND to AI GND, and wired AO0 to AI0. I am using Measurement and Automation Explorer along with a multimeter to see what voltage is being output and from what I have so far, the answer is yes. I am reading on AI0 what my multimeter is reading.
Message 11 of 26
(2,500 Views)
I have done nothing with scaling, so far. I will be using 200 VDC, when I actually put this in circuit but will cross that bridge when I get to it. For now, no scaling.
Message 12 of 26
(2,498 Views)
This is very impressive s-ware! The huge difference to what I am experienced with (Allen-Bradley, Siemmens, DirectLogix, etc....) is speed! Just thought I would throw that in here. 🙂
Message 13 of 26
(2,488 Views)
I'm sure NI would love to hear that feedback.  Setting up scales in MAX isn't too difficult.  You have various options for using a table, or a polynomial, and a few others.  You then save the settings in MAX and you can call them and use them in LabVIEW.  You then read your channel and it returns the engineering units you applied to it.  You can also programatically create the scales using DAQmx VIs, but in my opinion it is better to have it in MAX.  It adds a layer of obstraction that is nice to where my software doesn't care about the scale or how it is made, it just uses it.  No need to re-invent the wheel if there is software that handles scaling for you.
Message 14 of 26
(2,483 Views)
Just need to figure out how to establish serial connection with HP LCR Meter and I am in business. Pretty sure that DAQ Assistant can't be used, as it is not showing my COM3 connection. Probably need the VISA for this however, that's my next task. Thanks for your support.
Message 15 of 26
(2,471 Views)
It sounds like you are making some good progress, but let me suggest you open the Example Finder by going to Help >> Find Examples.  There search for Serial.  The example I'm thinking of is called Simple Serial.  It shows how to open, write, wait, and read some arbitrary data.  It has some functionality similar to hyperterminal.  There are more advanced features like Asyncronous vs Syncronous, and terminating characters but it is a good start, and it should list the COM ports that Windows sees.
Message 16 of 26
(2,463 Views)
You can use the simple example but you can also check to see if there is existing code for your instrument. Simply use Help> Find Instrument Drivers. If one exists, there is normally an example of how to use it.
Message 17 of 26
(2,459 Views)
Tried that for the first time, just now. This software keeps impressing me more-and-more, with each new thing I learn. I took the Core I and started Core 2, online training. This is the most intuitive, easy to learn, controls and automation software I have ever used. Thank you
Message 18 of 26
(2,439 Views)
This is the most intuitive, easy to learn, controls and automation software programming language I have ever used.
Fixed that for you. Smiley Wink
Message 19 of 26
(2,428 Views)
Thank you for correcting me. Smiley Happy
Message 20 of 26
(2,423 Views)
