11-22-2007 02:51 PM
11-22-2007 03:25 PM
11-22-2007 03:47 PM
ofahed wrote:
Why can you change the visibility of the caption just after you activated it once manually? Is that a bug and is there a fix?
11-22-2007 03:48 PM - edited 11-22-2007 03:49 PM
See image of example: (using LV8.2)
EDIT: After reading tst's post, I'd better go back and check if I missed something.. 😮
11-22-2007 03:52 PM
11-22-2007 03:55 PM - edited 11-22-2007 03:55 PM
I read the post again, manually changed the caption, ran the VI, and the caption changed during runtime using property node & LV8.2.
See image.
11-22-2007 03:57 PM
Hi Olivier,
Just saw your post.
Can you provide a bit more details about the first time working or not working? And maybe post your code..??
RayR
11-22-2007 04:08 PM - edited 11-22-2007 04:11 PM
11-22-2007 04:52 PM - edited 11-22-2007 04:53 PM
11-22-2007 05:00 PM
