update graph realtime
In the attached VI in labview 8.5, I wanted to display two plots on the same graph in real-time.  That is, for every iteration in the "for loop", the graph updates.  I am only able to do this with one of the plots (y1) but would like both sets of y-data to show up on the graph (i.e both y1 and y2).  Is there a way to do this real-time?
hiNi
(2,826 Views)
Do you have to use and XY graph? If not you migh try using the "Merge Signals" Functions.
(2,810 Views)
Accepted by topic author hiNI
This is possible to do with a XY-graph. The data the XY-graph accepts for plotting mutiple graphs are an array of clusters. The cluster consists of two arrays containing the x and the y values. I included the vi with the solution for you.
I hope this solves your problem.
Best regards.
(2,794 Views)
THANK YOU!!!
(2,781 Views)
