update custer elements in effecient way
So you have cluster with 20 numeric controls inside. After selecting element what you want to do?
Message 11 of 17
(938 Views)
           not controls but indicators, For now i just want to wire with random number, In future with daq Analog in.
Message 12 of 17
(935 Views)
Check the VI I posted some time back it shall help you. just replace the cluster with randon number.
With Regards
Miraz
Kudos is better option to thank somebody on this forum
Message 13 of 17
(924 Views)
Check attached VI. It will help I think.
Message 14 of 17
(910 Views)
Do they have to be in seperate loops?  Can they all just run in the same loop.  This would mean they would all have the same update rate.  But then you can put the code for each section in a case structure to disable it.  In the end, everybody supplies their value to the cluster bundle and you have your new value.  Store it in a shift register so that the disabled sections can just pass the "old" value.
Message 15 of 17
(907 Views)
        Yep they all run in a same loop and the rate is also same. But won't there be lag in update of the data to the previous cluster elements?
Message 16 of 17
(899 Views)
Accepted by topic author jay0909
Not really
Message 17 of 17
(874 Views)
