updata in database
Hello,Labviewers
    I have a question in database operation.I passed a labview cluster which contains different types data to an  access table field.This type is OLE in access.
    When I updata log I can't find a vi that pass the new cluster to access,I can but updata a string type,I have no ideal updata a cluster type.
Regards.
paulbin
from china
*The best Chinese farmer*
(3,057 Views)
Hi Paulbin:
I would manage a table with columns of different types instead of columns of cluster types: You can have 4 columns (2 DBL and 2 INT) instead of the cluster you want as OLE.
Then you could update every column with SQL sentences as you try to.
Aitortxo.
(3,044 Views)
Hi Aitortxo:
    I have another similar question.I have inserted successfulaccess log when I use cluster,it's binary data. Labview show error when I replace the cluster with a float number follow your advice,It's "insert into expression error".The diagram have no more change.
paulbin
from china
(3,023 Views)
