uograding from labview 8.5 to 2009
I'm thinking about upgrading from LabVIEW 8.5 to 2009.  We currently call a large number of VIs from TestStand 4.01 - What risks do you see in making this move (i.e. drivers, breaking code)
(2,680 Views)
The same risks one would see in updating, from, say 7 to 8, or 6.1 to 8.5. If you're using Toolkits then you should first check to make sure there are 2009-compatible versions of toolkits. As far as drivers are concerned, it's the same thing. What drivers are you using? If it's DAQ, then just make sure you get the latest DAQ software.
Some things will be different, but nobody can predict what problems you're going to have because we don't know what your code is doing. Your best bet is to look over the Release Notes for 2009 and see if you are using anything that has been drastically changed in 2009.
(2,660 Views)
