unstable output
I'm making pulses with NI-6733 board
I generate analog square pulse with "pulse" block in "signal
processing".
(labview 8.0)
I make multi channel output with Pulse block,waveform builder,and
daqmx write block.
Update rate is from 1,000 to 1000,000
It works,but output is very unstable.
The pulse must have two output value,but it often shows intermediate
value .
It even make pulse that oscillate between maximum and middle value and
never falls to 0.
Is it a hardware problem, or something that happens with labview
daqmx pulse often?
I will atttach screen capture soon
Message 1 of 10
(4,302 Views)
What voltage level are you pulsing at?  Have you considered using the timer/counter on the board instead?
Message 2 of 10
(4,298 Views)
screen capture  of code is included
Output is 1~3 V
I need to output 3 pulses to 3 channels. counter pin  was not considered
for that reason
메시지가 12-06-2007 12:46 AM에 sperelat에 의해 편집되었음
Message 3 of 10
(4,280 Views)
Is your output wiring properly terminated?
Message 4 of 10
(4,271 Views)
 Hi sperelat,
 Is there any change in the performance when you slow the sampling rate way down?
 Have you looked at the waveforms to see what will be generated?
 You can just create a indicator on the doubles and wire it to a waveform chart.
 Are certain update rates more stable than others? This would be the result of the sample
 clock being a integer division of 20Mhz.
 Do you see this behaviour with a resistive load? What is on the output of the 6733?
 Have a great evening.
 MatthewW
Message 5 of 10
(4,222 Views)
I tried to change pulse width and delay with given sampling rate.
Output became unstable if delay+width exceeds 7.
( sampling   100,000  or 1000,000)
It was also affected by increas of output from other channel.
Did anyone tried the code I posted with your own daq board?
I don't know if it's problem of NI 6733 board or problem of code.
Message 6 of 10
(4,211 Views)
You didn't post any code, just an image of your block diagram.
Message 7 of 10
(4,198 Views)
When I  wrote the word "code", it was block diagram..because labview doesn't have seperate code
for the block diagrams ^^;
Message 8 of 10
(4,181 Views)
But they do have VIs which you can post.
Message 9 of 10
(4,178 Views)
You should place an DAQmx-WaitUntilFinished between Start Task and Clear Task.
Felix
Message 10 of 10
(4,149 Views)
