unsafe behavior
hello all, iam currently using a SSR-RACK24 with an arduino uno. i have the 70-ODC5 to drive solenoids.
i have 5 leds to simulate the solenoids.
i have observed that right when i fire up the vi (which i'm posting here) all the leds turn on for a a fraction of a second, and then go to the off state. then i can switch them off and on.
note: i set all the switches to off before running the vi.
this doesnt cut it for me, I need to be certain that no load will be turn on without my concent.
i tried the arduino close, right before the arduino initialized to make sure the port is certanly closed, but it did not help.
how can i dont have that quick on state?
help will be greatly appreciated.
(2,842 Views)
You need different hardware!!! some type of failsafe to prevent the SSR24 from operating until the arduno is up and running.
"Should be" isn't "Is" -Jay
(2,840 Views)
As Jeff says, you need some additional hardware between the control hardware and the output hardware, as apparently there is a momentary condition before you have control. Now some hardware drivers have this built in, I don't know your current hardware.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(2,807 Views)
thanks for the replay lv_pro and jeff, i will look and see what piece of hardware can i add in the middle of the arduino and the ssr to avoid this momentary condition.
 any advice into this will be greatly apreaciated.
(2,804 Views)
One quick trick I use is to throw a pair of relays on the SSR boards power supply.  Require them to be in opposite states to enable the conrtol SSRs.
(2,780 Views)
