unload dll
I have a LV application that have some Exit problems. LV hangs. I think the
problem is related to unload problems of a dll. Normally the dll is unloaded
then the application is closed. Can I programmely unload the dll before i
close the application?
Best Regards,
Morten Pedersen
(3,349 Views)
You cannot programatically unload dlls. You have to either shut down your VI or close LabVIEW.
(3,349 Views)
Well, you can unload dll's manually, but only if you loaded them manually
(if you use LoadLibrary functions). The calling mechanism gets a bit more
difficult, if you do it like this.
LabVIEW probably uses LoadLibrary (or LoadLibraryEx) to load and unload
them, so I doubt that it will solve the problem.
Wiebe.
"Jeremy Braden" wrote in message
news:506500000005000000B7780100-1079395200000@exchange.ni.com...
(3,349 Views)
