universal time is not displayed on executable user computer
I have setup a timestamp indicator to be data bound to a Shared Variable.  The Shared Variable contains Universal Time. When I build the executable and run it on my development PC the indicator displays Universal Time properly.  When I install the executable on the user PC it displays the local time. Why?  I use LabVIEW Application Builder to build the installer.  The LabVIEW Run-time engine, VIs, subVIs, Shared Variable libraries are all installed and deployed on the user PC using the installer.  Is this a Windows issue?  I'm using LabVIEW 2011 on Windows XP PCs.
(2,916 Views)
If you have problems with the time stamp indicator in the user computer but not in your computer, you can review the following link that describes a possible solution to this issue:
http://digital.ni.com/public.nsf/allkb/ECA8521AA894ED6A862575D2006DCD04?OpenDocument
(2,884 Views)
Accepted by topic author faustina
definately a computer issue on the user side - thanks
(2,876 Views)
