unit conversion causes error in results
Hello all,
Please help!  I found an annoying problem with unit conversions.  I'm running LabView 6.1.  In my program, I read in a data file containing calibration data, then my program adds units to the data.  The problem is: after adding units, the number would be a little bit off.  I've tried changing precision from SGL, DBL, EXT, and I still have the same problem.
Attached is a VI showing the problem, together with screen shots of the diagram and front panel.
Sunny
(2,572 Views)
Hi Sunny,
      Right-click on the "Input" control (Front Panel) choose "Format and Precision" and change the "digits of precision" from 5 to 8.  Input is being rounded-up from "0.89999962" to 0.90000.  If you do the same for "Before conversion" you'll see that all the values are really in agreement.! Smiley Happy
Cheers.
"Inside every large program is a small program struggling to get out." (attributed to Tony Hoare)
(2,564 Views)
