unable to set ECP parallel port in byte mode
I'm trying to set the control bit 5 of the control register of the parallel port of my PC running windows XP . But the bit doesn't set at all and remains at logic 0....but the other bits of control register can be set or reset...I'm trying to do this using a C program.....
The program runs fine but My ECP parallel port doesnt set itself in byte mode/bidirectional mode...
    #include <stdio.h>
#include <windows.h>
#include <conio.h>
/* Definitions in the build of inpout32.dll are:            */
/*   short _stdcall Inp32(short PortAddress);               */
/*   void _stdcall Out32(short PortAddress, short data);    */
/* prototype (function typedef) for DLL function Inp32: */
      #define PPORT_BASE  (0x378)
#define PPORT_CTRL  (PPORT_BASE+2)
     typedef short _stdcall (*inpfuncPtr)(short portaddr);
     typedef void _stdcall (*oupfuncPtr)(short portaddr, short datum);
int  main()
     HINSTANCE hLib;
     inpfuncPtr inp32;
     oupfuncPtr oup32;
     short x,y;
     int i,pinput;
     /* Load the library */
     hLib = LoadLibrary("inpout32.dll");
     if (hLib == NULL) {
          printf("LoadLibrary Failed.\n");
          return -1;
     /* get the address of the function */
     inp32 = (inpfuncPtr) GetProcAddress(hLib, "Inp32");
     if (inp32 == NULL) {
          printf("GetProcAddress for Inp32 Failed.\n");
          return -1;
     oup32 = (oupfuncPtr) GetProcAddress(hLib, "Out32");
     if (oup32 == NULL) {
          printf("GetProcAddress for Oup32 Failed.\n");
          return -1;
/* now test the functions */
          /*****  One more time, different value */
    i=0x37A;
                     /***** And read back to verify  */
            (oup32)(PPORT_CTRL,  0xEF);
             x = (inp32)(i);
              printf("port read (%04X)= %04X\n",i,x);
     FreeLibrary(hLib);
     getch();
                         return(0);
(3,370 Views)
And you posted this question on a LabVIEW forum because.....
Certified LabVIEW Architect
LabVIEW Champion
(3,366 Views)
Hey Himanjim,
I remember doing something similar to this a long time ago, and I just followed the following article to make it succeed. Custom Project: Controlling LED's with a Parallel Port
Nick Delbar
(3,343 Views)
Thanks a lot mr. Nick....
I actually solved the problem by changing the BIOS settings of my || port from ECP to bidirectional
(3,332 Views)
