unable to retrive data continously from external device
I wrote program to read the values of external devices through serial communication but not working properly. when I run the program , First time all sessions are opened and read values as expected but the execution time between the loops is 2 seconds. secondtime, all operation executes as expected but  values are not reading and the execution time between  the loops is 50 ms.  I attached VI and sequence structure. Kindly support me.
(3,885 Views)
Hi prabhu,
it seems you forgot to implement (most of) error handling at all!
Don't you think it would help to know atleast the error numbers?
(For other readers: the VI contains a lot of Plasmonique ModBus VIs…)
(3,855 Views)
Hi
(3,849 Views)
Hi Prabhu,
right-click the error cluster to read the explanation…
(3,846 Views)
Thanks Mr. Gerdw,
No. I took youtube tutorials. I will read the NI beginners resource as you recommend.
The error warning is attached. kindly support what that error means...
(3,841 Views)
Hi Prabhu,
- it's not an error, it's just a warning
- there might be more data available then was read
(3,837 Views)
Mr.Gerdw,
Is it possible to write simple Program for my operation. If so, Suggest me. Also, If any error in my program, Kindly notice me.
(3,829 Views)
