ultrasound sensor
need help to control the speed of my motor according to how far is an object infront of my ultrasound sensor. eg if an object is infront of my sensor the motor will start to slow down, if it gets nearer to the sensor the motor will stop
(2,741 Views)
Hi dennis,
which help do you need?
Looks pretty simple:
IF distance > limit THEN full speed
IF min < distance <= limit THEN half speed
IF distance <= min THEN stop engine
(2,717 Views)
how do i write de min and limit
(2,713 Views)
Hi dennis,
"min" and "limit" would be controls on the front panel of your VI…
(2,710 Views)
can i ask min and limit of what?
(2,706 Views)
Hi dennis,
Sure you could ask.
But I thought you already knew that as your original question was this:
(2,698 Views)
