u480 camera
Hello everybody,
I´m using a camera from Thorlabs (DCC1645C) for surface measurements. I´m trying to use it with Labview, I´ve got the drivers installed but I do not have any idea how to use them (since "drivers help" seems not to work).
Has anyone ever used this camera? Any help is welcome!! Smiley Wink
(6,407 Views)
@lacorgui wrote:
Hello everybody,
I´m using a camera from Thorlabs (DCC1645C) for surface measurements. I´m trying to use it with Labview, I´ve got the drivers installed but I do not have any idea how to use them (since "drivers help" seem not to work).
http://www.thorlabs.de/thorcat/ITN/DCC1645C-SoftwareManual.pdf
(6,400 Views)
Thanks nyc,
I know how to use this application. However my purpose is to implement the use of the camera in Labview using the drivers installed instead of using the application.
Smiley Wink
(6,394 Views)
@lacorgui wrote:
Thanks nyc,
Smiley Wink
Drivers are not meant to help you learn how to control the camera.
(6,386 Views)
I know, I read the manual and other .pdf files in order to understand the camera way of working. In fact, I´ve use the camera before, taking pictures and videos. However, due to my research job, I must implement, at least, the viewer of the camera in a Labview interface. For that, I think using drivers is the best option since they are based on VISA resources.
I´ve found an old post (getting started with thorlabs lc1-usb (2007)) with some examples but unfortunately vi examples files are not in the server any more (old_example).
Hope to find a way to do it!
(6,375 Views)
You may want to try installing the older UC480 version 4.20 software.
http://www.thorlabs.de/software_pages/ViewSoftwarePage.cfm?Code=ThorCam
It includes a manual about the LabVIEW drivers which are *not* included. However the explanation may match the VIs you have that are installed with the newer software.
It also includes a VB.NET example using ActiveX. That may be translateable into LabVIEW.
By the way, there are most likely a lot of helpful resources installed on your PC.
Look in the Program Files directory under Thorlabs.
(6,357 Views)
Upon installing the Thorcam software, the labview VIs are installed as well.
usually they are found in the following
directory C:\Program Files (x86)\Thorlabs\Scientific Imaging\DCx Camera Support\OtherDrivers\LabVIEW\8.x_32-bit
hope this helps
(5,986 Views)
