typemutation error code
We are running 6 computers that each control an engine dynamometer setup and does the data acquisition. We are using FieldPoint modules with the main processor module being 1601's. Once in a while we are getting a 'typemutation.ccp line 361" error. When this comes up, the software freezes. The attached file is a copy of the window that pops up with this error. A fellow engineer has searched your website and not found anything relevant to this particular error or a possible cause. Please advise if possible. Thanks.
(2,634 Views)
There is no telling what is causing that error. If you want to try a more recent version of LabVIEW, go here for the evaluation version.
(2,634 Views)
