two while loops working in parallel at the same time
Hello, how can I run a .vi with two while loops working in parallel at the same time? . I want that when I run a vi both can be activated o desactivate, but I can't get it. What can I do?
Thanks a lot.
Luz
Message 1 of 9
(4,257 Views)
It may be not exactly what you want but it will work.  You can not deactivae a loop so see attached code.  Should work for most applications.
Matt
Message Edited by mfitzsimons on 05-26-2006 07:37 AM
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
Message 2 of 9
(4,243 Views)
Please, I can open your file because a have labview 7, can you send me it again in this version.
Thanks a lot,
Luz
Message 3 of 9
(4,239 Views)
It is time to upgrade!  ere you go.
Matt
Message Edited by mfitzsimons on 05-26-2006 07:45 AM
Matthew Fitzsimons
Message 4 of 9
(4,238 Views)
I have a similar problem before. I also used a local variable to stop another loop. It didn't work. Now I understand the key is that we must use "switch" instead "latch" for that stop button.
Message 5 of 9
(4,226 Views)
I can't get it. I want to do an adquisitiong or another thing. I send you an example of I want to do. If I do the program step by step I notice that there is an error 200279 in the adquisition, what means that there isn't sincronization. Can you help me, please?
Thanks.
Luz
Message 6 of 9
(4,207 Views)
Put Delay of 100ms in both while loops, it will help in balancing execution of both while loops. Or use State machine pattern to do more tasks in Single While loop.
Hope this would help.
Message 7 of 9
(4,189 Views)
What is state machine pattern?
Message 8 of 9
(4,178 Views)
Message 9 of 9
(4,173 Views)
