two plots to waveform graph
I need to use cursors on my waveform, so need to use waveform graph. I have 2 signals and when I use build array, it combines both signals into one plot. The waveform graph only show one plot. How can I have 2 plots on my waveform graph?
(973 Views)
Hi wan,
Why don't you look at the context help for the waveform graph?
It explains how to create multiple plots…
LabVIEW also comes with a huge example library and there are examples on how to use graphs and charts. Did you examine those example VIs?
(966 Views)
Hi Gerd,
The context help does not explain how to use the waveform graph as chart (continuous plot) with multi plots. Most of the example I checked out do multiplot on waveform graph is read data and plot.
The build array joints both data to form into a new single data.
The build waveform and merge signals does not show any plots on the waveform graph.
(952 Views)
Hi wan,
  • The help explains how to show several plots ("multiple plots").
  • A graph is a graph and not a chart.
    When you need behaviour like a chart you need to buffer the data on your own in the same way as a chart would do.
  • The BuildArray builds an array in the way that YOU have configured. When you need a different (kind of) array then YOU need to create this array in a different way!
  • Using ExpressVIs to convert good, nice waveform/array data into DDT wires will not help at all.
    Try to get rid of ExpressVIs as soon as possible…
(947 Views)
I have created buffer but the graph is charting with multiple lines. I have remove Express VIs.
(941 Views)
Accepted by topic author indcon_wan
Hi wan,
see this example:
My example creates 8*2 plots…
Why did you enable the "Transpose Array" option in the graph settings? Do you know the consequences of that setting?
(936 Views)
Hi GerdW,
I managed to find an example to solve my problem. Thanks for your suggestion.
(902 Views)
