two input digital/ boolean latch
Hi guys,
I have a difficulty in coming up with a working solution for the following scenario.
I am simulating a motor combustion cycle where the CAD vector runs from [-360,360] and this happens periodically (for every combustion cycle). I have a need to detect a certain CAD value before and after TDC and send out a logic high for that duration.
As per my existing solution, when I detect a value before TDC, I output a 1 from that detected value till TDC and when I detect a value after TDC, I output a 1 from the value till the end of the cycle i,e 360 CAD value. But my interest is to output a logic high in between the two detected values.
I am aware that or have looked around the forum that this can be done using a while loop with event structures and shift registers. But the solutions I found were for one input only. I cant get my head around this, and I appreciate the help.
Message 1 of 1
(2,516 Views)
