two dialog logs
I am working a program that would utilized two dialogs vi.  When the program starts, dialog 1 would pop up to gether information from user (close afterward).  Then, dialog 2 (main program) will pop up while the main program is running.  My problem is that I want to use dialog 2 as my main VI, but I don't want to use it to start the program, since dialog 2 has a lot of information on it, and a start button just don't fit.  I am trying to find the best way to manage the dialogs.  Below are what I am thinking.  Let me know what you think.
1.  Create a dialog 0 that would be my main VI with a simple dialg that would allow the user to initiate the program, and it will call up dialog 1 and dialog 2?
2.  Use dialog 2 as my main vi, but it will hide itself and show dialog 1 ASAP when the user first starts the program.  Dialog 2 will reappear again when dialog 1 is done.
3. Squeeze a start button on dialog 2?
Yik
(3,843 Views)
4. Start dialog1 and then:
   4.1 store the gathered infos (into globals, functional globals, ...)
   4.2 call dinamically the main program (dialog 2)
   4.3 exit from dialog1
Marco
(3,805 Views)
Would you tell me what are the advantages when I call VI dynamically?  I have not tried it before, since I don't know when is the best time to use it.
(3,796 Views)
Actually, here the only advantage is that this will allow dialog1 to exit,
and you can forget about it once it has gathered data from the user...
Marco
(3,788 Views)
Just an example of what I mean:
(3,785 Views)
Couldn't I just do the same thing if I put the subvi inside my main program and configure the subvi so that the front panel of the subvi pop up during run time?
(3,777 Views)
Given your numbering, why not have dialogue 2 start off and have it immediately call dialogue 1.  When user is done with dialogue 1, it closes to reveal dialogue 2?
(3,770 Views)
