turn on and off multiple plots in charts
I would like to be able to turn on and off certain plots when I chart the data that I collect.
Right now I use case structures, and if I want the plot turned on, the data for that particular plot gets added to an array, and it does this for each channel of data that I collect.
The problem is that when I turn off certain plots, the colors of each plot don't stay the same, and when I turn off a plot, the plot dissapears from the chart legend. I want the colors to stay the same and the chart legend to stay the same.
Does anyone know how to do this? Or can someone point me in the direction of an example like this?
Thanks a lot for your help!
Sunny
(2,925 Views)
You can use property nodes to set which plots you want visible/invisible. The colour remains current with each plot. Note that the "convert to dynamic data" type uses rows as channels in the vi below, but it will depend on how you've stored your data arrays.
(2,918 Views)
How would you do this if you do not know how many plots will be shown (I am reading from a .csv file)
(1,238 Views)
Hi crouxel,
Once you read your CSV you KNOW the number of plots!
So you can use a loop to iterate over all available plots…
(1,215 Views)
