turn a text file content into a dropdown box
Hi Folks,
I have a text file filled with commands. and i would like to turn this text file into a dropdown ring box, how do i do that??
textfile attached.
Lee
Message 1 of 10
(4,083 Views)
What part are you having problems with? Reading the file? Extracting a specific part of a row? Populating a ring?
What's supposed to go into the ring? Many of those lines are exactly the same.
Message 2 of 10
(4,067 Views)
I am having problems on Extracting a specific part of a row and  Populating a ring? I can read a file. the attached is just a sample test file that i was working on, once i figured out the aformentioned problems i will use the real file.
Lee
Message 3 of 10
(4,060 Views)
OK... let's try asking this a different way. For the file you posted, what do you want to show up in the ring?
Message 4 of 10
(4,055 Views)
i want it to show the below on the dropdown ringREAD: Optical Power,60420000
READ: Optical Power,60420001
READ: Optical Power,60420002
READ: Optical Power,60420003
READ: Optical Power,60420004
READ: Optical Power,60420005
READ: Optical Power,60420006
READ: Optical Power,60420007
READ: Optical Power,60420008
READ: Optical Power,60420009
READ: Optical Power,604200010
READ: Optical Power,604200011
READ: Optical Power,604200012
READ: Optical Power,604200013
READ: Optical Power,604200014
READ: Optical Power,604200015
READ: Optical Power,604200016
READ: Optical Power,604200017
READ: Optical Power,604200018
READ: Optical Power,604200019
READ: Optical Power,604200020
READ: Optical Power,604200021
READ: Optical Power,604200022
READ: Optical Power,604200023
Message 5 of 10
(4,051 Views)
If you go to the example finder and type in ring there are a few examples that might help you.  If the examples do not help try posting your code so people can see what you have done and point you in the right direction.
Message 6 of 10
(4,044 Views)
i can't find the example finder, where is it?
Message 7 of 10
(4,038 Views)
Accepted by topic author lee40002
That's not extracting anything from the lines. That's just dumping the contents of the file directly into the ring. That can be accomplished by simply doing this:
Message Edited by smercurio_fc on 06-03-2010 05:03 PM
Message 8 of 10
(4,036 Views)
Help -> Find Examples.
To learn more about LabVIEW it is recommended that you go through the tutorial(s) and look over the material in the NI Developer Zone's Learning Center which provides links to other materials and other tutorials. You can also take the online courses for free.
Message 9 of 10
(4,032 Views)
thank you, my cowoker and i have tried to figured that out for the whole afternoon. We made it far more complex than necessary.
Lee
Message 10 of 10
(4,023 Views)
