trying to update labview run time engine
I have already upgraded from 6i to 6.1 but for some reaqson RTE did not upgrade
(2,621 Views)
Hi honeybear,
LV 6i and 6.1 are using different RTEs. So it is not needed to upgrade the RTE they will coexist on the same machine.
You should find (assuming windows) your RTE files in the folder %program dir%\National Instruments\shared LabVIEW Run-Time\.
Have you installed 6.1 beside 6i so you could use both (which is the default behaviour) or have you installed it in the same folder?
Have you uninstalled 6i bevore installing 6.1?
Waldemar
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
(2,621 Views)
You can download the LabVIEW 6.1 run-time engine from the LabVIEW downloads page.
Zvezdana S.
(2,621 Views)
