trying to add mindsensors device to palette
I'm trying to add new category to the function palette' and need to use "Tools->Advanced menu to do it. The problem is that the "tools" menu I get (Labview 2010 for education ) contains only few options and "Advanced" is not one of them. How can I get the full menu ? This is The Tools menu I get In previous versions There were much more itemsin this menu, including the "Advanced" option.
Tools menu t
(2,213 Views)
Found the answer in another question which was answered in the forum. The solution to the problem is to change the mode of labview from "labview for Education" to "Labview"
This is the original answer:
If you want to use the Edit Palette Set tool in LVLM, you will need to first switch into the normal LabVIEW mode. You can do this by going to Tools:Choose Environment, and selecting LabVIEW. This will give you the full set of LabVIEW menu options.
I tried it and it realy gave me the full list of items in the "Tools" menu' including the "Advanced" menu.
(2,176 Views)
