try to send e-mail
Hello everyone! I try to send e-mail but get error. See attachments. Please, help me.
Message 1 of 9
(4,606 Views)
Hi
Check attached VI
http://decibel.ni.com/content/docs/DOC-2401
Anil Punnam
CLD
LV 2012, TestStand 4.2..........
Message 2 of 9
(4,598 Views)
to Anil Reddy: GmailLV86.vi is working. It is nice. But:  1) if I don't want to use gmail? 2) Why "SMTP send email" doesn't work? Can I use standart vi-instruments in "SMTP" group in "Data comunication" in LabVIEW?
Message 3 of 9
(4,562 Views)
I think you can use the same VI ..Just change the settings like SMTP server, Port number, SSL based on your settings...
Anil Punnam
CLD
Message 4 of 9
(4,556 Views)
Just change the smtp server.
The most likely reason is that the server you are trying to use requires authentication. Most SMTP servers nowadays are like this. The SMTP VIs that come with LabVIEW do not support authentication.
Message 5 of 9
(4,546 Views)
да, похоже что сервер на рамблере все таки требует авторизации (рамблер помощь). авторизация не включена в выполняемые функии SMTP Send Emai VI, поэтому придется использовать вышеуказанный пример.
удачи!
Misha
Message 6 of 9
(4,542 Views)
to Anil Reddy: thank you for help; to smercurio_fc: thank you for explanation; to mishkin: спасибо, брат )
Message 7 of 9
(4,516 Views)
Hello
i get the error -7 when is send this mail.
 _tmp1 = InetSendMail ("smtp.gmail.com", "supersnowV7@gmail.com", "info@technofase.com", "Test Mail", "Prova", "");
I create the mail with gMail but i can't send it.
I try to send the same mail with LIVE MAIL and i send it (so no problem by the Mail Server).
Can somebody help me ?
Regards
Message 8 of 9
(4,339 Views)
@TECHNOFASE wrote:
Hello
Regards
You have posted to the wrong forum. InetSendMail is a LabWindows function. This is the LabVIEW board, which is the graphical programming language. You need to post in the LabWindows board, which I see you've already done
Message 9 of 9
(4,307 Views)
