triggering peaks dynamic data type
Hello all,
I am trying to record samples based on triggers. The triggers are peaks above certain value and below a certain value. My attempt is to keep data as dynamic data type throughout. I tried using the trigger and gate express VI. I am not able to get the code working as planned. What I get is basically a level corssing trigger which I am not trying to simulate.
Has anyone worked on a similar issue of coding.
Himanshu
(2,662 Views)
If your current VI is not working, then it would be best if you post it so we can see what is going wrong.
(2,646 Views)
