triggering event by time of day
one question is how do you make multiple absolute times, and is it possible to use this without the date be taken into account so that it can run forever.
Message 21 of 25
(2,379 Views)
The example Jarrod posted is using multiple times.  The Timestamps input is an array of as many times as you want.
Alex Person
NI-RIO Product Support Engineer
Message 22 of 25
(2,360 Views)
okay but my other question was can you make the time stamps work without date
Message 23 of 25
(2,343 Views)
and when i test it with an array, the array has a different line. The input is a sink and the array doesn't match. It comes up with an error
Message 24 of 25
(2,327 Views)
When looking at the properties for the timed sequence structure, make sure you have the Built-In Timing Source Type set to 1 kHz <absolute time> instead of the default 1 kHz Clock.
To make the timestamp ignore the date, you have to rebuild it with the current date.  The attached example is horribly ugly and possibly complicated but all I was able to come up with for the moment.  If anyone has any improvement suggestions, please post them.
Alex Person
Message 25 of 25
(2,286 Views)
