Hello;
I'm not sure if I understood your application. You mention trigger pulses, but it seems you have an external pulse train clocking the analog input task.
If that is the case, you can't have onr of the Analog Input channels being clocked by an external clock pulse train and another channel, of the same board, clocked by the internal timebase.
Regards
Filipe A.
