triggered Analog Input
I'm new to labview programming.
I want to acquire 1 scan( 3 if necessary) of data with every trigger.
The trigger is created by gating counter 0 with the
update signal from the Analog output to generate a delayed pulse.
This pulse will be used as the trigger for the acquisition.
I want the input to start at the same time as the output and the
acquired
data is to be saved to disk.
Thanks for you help.
Erin Ryan
Message 1 of 1
(2,829 Views)
