trigger start the prog
Hi there.
In my prog i have a exponential decaying sine wave inputted from a DAC card. Im looking to know what is the best way to make my prog start recording results when the input voltage from the DAC card is greater than a certain voltage and then finish when the voltage falls below a certain voltage value. I have the prog stopping when reaches a certain value using a while loop but cant get the other to work with it(i.e. trigger starting). I would appreciate any help.
Cheers
Karen
(2,898 Views)
You could do something similar to the example I have posted. it is not much and only took about a minute to do, and it is not the only way but maybe it will get you started
Joe.
"NOTHING IS EVER EASY"
(2,886 Views)
Hi Karen,
Thanks for your post.
Joe's code should give you the functionality you're looking for. If you need any further help then please let us know.
Thanks for posting Joe.
National Instruments | Northern California
(2,861 Views)
