trigger oscilloscope lt354m
My problem is the following: I want to recognize when the oscilloscope triggers and after that start saving the data for the oscilloscope.
I already have the drivers for the oscilloscope and I have already done the part for saving the data; my only problem is recognize when there is a trigger on a channel so I can start with the next step.
Can anyone help me?
Message 1 of 50
(4,034 Views)
I haven't looked at the driver or used that particular model but usually there is an OPC? query that is used. OPC? stands for operation complete. Please refer to the manual.
Message 2 of 50
(4,024 Views)
No OPC? query unfortunately.
Message 3 of 50
(4,013 Views)
Please double check that. The command is mandatory.
Message 4 of 50
(4,004 Views)
I can't find it, sorry. But I am wondering if there is like a control which turns on when the trigger comes and turns off when there is no trigger.
Message 5 of 50
(3,998 Views)
Are you just looking in the driver or in the scope's manual? There could very possibly not be a driver function since you just do a write and read inside of a loop.
Message 6 of 50
(3,988 Views)
You can't find it?
Read the manual AGAIN.
No, there is not such "control" that you write of.
Message 7 of 50
(3,986 Views)
I have searched again but I didn't find anything.
Message 8 of 50
(3,980 Views)
I find that very hard to believe for a LeCroy scope.
Message 9 of 50
(3,975 Views)
It's In the manual that I just looked at - http://teledynelecroy.com/doc/docview.aspx?id=2950
What manual are you using?
Message 10 of 50
(3,968 Views)
