trigger circuit
Hi! I was wondering how a timer circuit can be trigger by Labiview
programming? Instead of turn on/off the switch manually, can Labview
do this job? I only have DAQ card. If impossible, what kind of card
that you recommend? Thank you. cheers!
from tom
(3,113 Views)
Tom;
You can use the two counters of your DAQ board to set up a timer, and you can have the timer started based on another condition, such as Analog Input trigger, or Analog Output operation.
I'm attaching an Application Note which talks about synchronization of multiple DAQ tasks. You can use that as a start point to set up you application.
Hope this helps.
Filipe
(3,113 Views)
Refer to the version of this Application Note in the Developer Zone to make sure you have the most up-to-date version.
Kelly H
LabVIEW Documentation
(3,113 Views)
