triangle detection in image
Hi. i need help on making a vi for detecting triangles in an image. IMAQ Detect shapes has no provision for triangle but for circle, ellipse an d rectangle. Please help. Anyone developed this can elp me please.
Message 1 of 20
(4,723 Views)
Try pattern matching available with the Vision development module.
Message 2 of 20
(4,714 Views)
Anand,
I dont have to pattern match  cuz pattern match you need to feed another image for pattern detectiion. I need that within a single image i should detect circle,triangle and rectangle. I am successful for cirle and rectangle cuz of IMAQ Detect shapes , but have no idea how to do for triangle.
Message 3 of 20
(4,707 Views)
Do you want the red overlay you mentioned in the output image to be a triangle or is rectangle overlay ok? We can do both and thanks for starting a new thread
Message 4 of 20
(4,693 Views)
Kaus please try this
Message 5 of 20
(4,678 Views)
Anand,
If want you can use pattern matching. You can use more than one template if required.
Message 6 of 20
(4,672 Views)
@muks: thanks gor sharing. yeah if we want we can develop the triangular overlay through hough lines and can start as a new thread.
Message 7 of 20
(4,660 Views)
Kaus,
Creating triangular overlay through lines will a bit tricky. The triangle you posted are all same so you might be able to do it but for a rotated and scalene triangle the overlay will be difficult one.
You can continue in the same thread if your overlay part needs some modidication. This is afterall your threadSmiley Happy
Message 8 of 20
(4,654 Views)
thanks yeah. But this vi has a short coming. If i attach rectanglar shapes, it is detecting them too which it shouldnt. I am in need of a pure, only trianlge detector.
Message 9 of 20
(4,650 Views)
Then i require a image that has all the shapes in the same image
Message 10 of 20
(4,643 Views)
