tree
Hi every1,
I am playing with tree. I have one problem. I have attached my code as well as 2 images. One is my current output and other is one that i want. Please help me. I want to know how to use"OUTDENT" option in my code.
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
(3,450 Views)
Accepted by topic author Gak
Hi Gaurav,
Currently you specify "A" as parent object of "B". Parent should be an empty string to insert a top level item.
Hope this helps,
Daniel
Message Edited by dan_u on 09-30-2009 11:54 AM
(3,431 Views)
Thank you it worked.
Gaurav k
CLD Certified !!!!!
(3,421 Views)
