tree control or multicolumn listbox vertical alignment
Hello, here is my problem: i use a tree and i need to resize it programmatically, so i change the height of all cells. When i resize it, there is no more vertical alignment between names(text) and tree's branchs.
This problem even occurs with multicolumn listbox: when i resize cells, the text is no more vertical centered....
Thanks a lot for any help
(3,468 Views)
Hi Zagarro,
National Instruments is aware of this cosmetic problem and is going to fix it in the future releases of LabVIEW.
As a temporary workaround you might want to increase the text size so that the text keeps aligned with glyphs or you can use multiple lines items.
AlessioD
(3,468 Views)
So, now it's 2011. It seems like this issue has not been addressed yet. Any good work arounds? I'm trying to have larger rows without extraordinarily large text. I am using multiple lines to get the desired effect; however, the item symbols are vertically aligned to the top, so they don't look good.
Chris
(2,990 Views)
