tree control choose a tag by more than one parent tag
Smiley Sad
i have made a tree control like this:
- 70002
            - 50001
Message 1 of 15
(4,827 Views)
Aha... can you give a little bit more details please... seems like you accidently pressed "post" Smiley Very Happy
Epictetus
Antoine Chalons
Message 2 of 15
(4,822 Views)
Sorry,
I have made a tree control like this:
- 70002
           - 50001
           - 50002
- 70001
           - 50001
           - 50002
           - 50007
I want to put a child tag under the tag 70001/50002. How can I do this by using the addobject method? Can I give the method a path (at the parent object connector) like this 70001/50002?
thankyou
schwede
Message 3 of 15
(4,816 Views)
Attached is a vi, that shows how you could do it, if you don't need to get deeper in the hierarchy.
Just set all values to default (menu > edit > reinitialize all to default). Then enter a root node (70001 or 70002) then the node, which should act as parent for the new item and finally enter the new item.
Be aware, that there is no check, if there are more nodes available in the loop. It is just to give you an idea - not a full featured solution.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
Message 4 of 15
(4,801 Views)
Smiley Very Happy
Thankyou works great ...
Smiley Very Happy
Message 5 of 15
(4,793 Views)
Hye Becktho !
You have just post this VI with LV8 version....
I know there is some issue about conversion but may you post the vi "additem.vi" in LV7 version
Julien
Conception Informatique et électronique
CNRS LCSR Web
Orléans la Source FRANCE
Message 6 of 15
(4,743 Views)
Here is a copy of the Additem.vi saved in LabVIEW 7.0 format.
-D
Message 7 of 15
(4,738 Views)
Thanks a lot for this version 7 VI
5 stars are the result of your help ....
I try to understand how a son might be added in a tree. In fact I try to (re) make a VI to use the 'create units' fonction which is fixed into Labview soft....
I
Julien
CNRS LCSR Web
Message 8 of 15
(4,729 Views)
I post the VI that I am programming
I try to insert a son under a parent tag..
The parent are correctly inserted in the tree but when I try to insert the corresponding 'son' with parent tag  the  error 1088  appears...
and  the explanation is not helpful....
Please anybody might give me some explanations
Julien
CNRS LCSR Web
Message 9 of 15
(4,729 Views)
Oupss forget to post the VI
Here they are...
Julien
CNRS LCSR Web
Message 10 of 15
(4,726 Views)
