transpose a 1d array column to row
Hi, i know there are alot of other posts around this issue but i can't get any of the solutions to work for my paticualr issue.
I have an 1D array that is a column format, but i want to transpose it over so it can be put with another 1D array and plotted, i've tried the usual stuff but i can't get it ito work.
help!
John P.
VI attatched, problem at far right of front pannel. Ta!!
(13,230 Views)
Hi John,
you want to concatenate those 1d arrays? Right-click the "build array" node and select concatenate mode!
You cannot transpose 1d arrays - there's no mathematical way to do so. Yon can change the look of the array indicator to show a row instead of a column...
(13,227 Views)
Hi John,
I changed your vi a little bit, it seems you took the wrong function to build the graph...
(Somewhere I linked to the wrong vi as the IMAQ part is missing in my LV installation.)
(13,210 Views)
