transparent cluster ?
watch your CPU usage before you open this vi
then open this vi and look at CPU usage  ( you don't even need to run it)
- James
Using LV 2012 on Windows 7 64 bit
(3,980 Views)
hello,
        Give 50 ms delay after u can run.after that u see CPU performance. this is for continuos run mode.
Sivaraj M.S
CLA
(3,961 Views)
Transparency is a tough thing for screen updates, for every element LabVIEW has to look behind the element (every boolean), what's the color, and there it finds another transparent color (the cluster), there it finds the FP background, this causes a lot of work, only if the FP is visible.
Not really a bug, just something to keep in mind when you design a gui.
Ton
My LabVIEW Ideas
(3,951 Views)
I have used transparent buttons before but this is a transparent button inside a transparent cluster
for it to use up 30% + on a 2GHz machine without even running the vi is a little excessive don't you think?
- James
(3,930 Views)
Yes I agree, it is quite a lot, but I think it will lower as soon as some code starts running (at least I hope).
But now the main question, why an invisible boolean?
You could filter Mouse Down events, or hide the control.
Ton
My LabVIEW Ideas
(3,918 Views)
Your other problem is the fact that all your transparent objects overlap. You have actually 10 buttons on the cluster (most hidden). Arrange them a little neater and things will probably improve.
I cannot really tell, because my CPU does not really show anything dramatic (2-3%), even in your version.
Why does the cluster container need to be transparent? Can't you color it the same as the background instead?
(3,912 Views)
I am using labview 8.5.1.F4
one of the fixes for .F4 states to have fixed the overlapping controls problem.
when I simply have transparent buttons i do not see this CPU usage problem it is only when I add them into a cluster and the more i add to the cluster the worse it gets
- James
(3,886 Views)
