transfer measurement array to excel
so, i have the array and it takes measurements and data get dumped into the array no problem. after taking measurement i want to save the data in the excel template that i have created but i am having a hard time doing it.
Can someone help or has a better way of doing things?
(481 Views)
First, if you have an Empty Template, you don't need to wire it to "Create Report".  And second, if you want to write to Excel, don't "HTML" to Report Type in "Create Report".
If you look probably less than a dozen posts before yours, you'll find an earlier response I made tonight to someone else wanting to know about creating an Excel Report.  I told him how to find a "Revised Generate Excel Report" example that might help you, too.
(437 Views)
