trafag pressure transmitter ouput
Hi all,
I have trafag pressure transmitter which has an output of 4-20 ma, ni usb 6229 daq and i am working in labview.Do i need another hardware for this system to measure the pressure?
Regards
Message 1 of 20
(5,558 Views)
Just the precision resistor across the current output since your board can only measure voltage.
Message 2 of 20
(5,546 Views)
i have also melles griot amplifier.if i connect sensor output to amplifier input then amplifier output to daq input, could i have an voltage value?
Message 3 of 20
(5,536 Views)
What sort of amplifier? I'm only familiar with their laser/optical products. Provide the data sheet. Seems expensive compared to a single resistor for under a dollar.
Message 4 of 20
(5,528 Views)
in pdf file, the top is mine.i am not sure whether it is useful for this kind of applications.ressistor can be a cheap option, but this amplifier is provided by lab not paid by me 🙂
Message 5 of 20
(5,522 Views)
Like using a sledge hammer to kill a fly.
Message 6 of 20
(5,515 Views)
i connect a ressistor which is 1700 ohm.how can i make the calibration?
Message 7 of 20
(5,461 Views)
Message 8 of 20
(5,503 Views)
Why would you pick that value? Do you know Ohm's law? At 20ma, you would have 34 voltss and that's way outside the range of your DAQ. A 500 ohm gives you a max of 10 volts. You just create a custom scale in MAX. Follow the directions.
Message 9 of 20
(5,480 Views)
this time i connect 470 ohm whis means min. voltage is 1.88 and max. voltage is 9.4
According to this values and from the datasheet of sensor its range is 0-100 bar. with lineer relation i calculated the equation y=13.3x-25
Here x is the voltage from the daq -25 is offset and y is my pressure value.But i still cannot read reasonable values.
Message 10 of 20
(5,451 Views)
