tracking LabVIEW runtime execution
I'm trying to find the section of my application that causes LabVIEW to
crash with a memory exception error 0xC0000005. The problems was first
produced under LV 5.1.1 and then after some changes to allow the code to run
on LV 6i.
I have tried putting debugging output using the outputdebugstring to allow
me to track execution with a debug viewer. I have also tried using the
debugging=true and memorychecking=true options to see if I could get any
additional information that would allow me to isolate the problem.
What I'm looking for is a debugging option that would output debug traces
from the LV code, that is as it enters a LV function such as a DAQ function
it would display on the debugging viewer that the NI-DAQ function blah has
run.
Now this presupposes that such functionality exist within LabVIEW, the
options debugging=true and memorychecking=true give me some hope that there
is still undocumented INI file settings that would allow one to isolate
causes for crashes.
Of course it goes with out saying that the problem is not totally
reproducible and single stepping with animation is not an option.
Cheers,
Peter (knocking ones head against a brick wall).
(3,682 Views)
> on LV 6i.
> run. Now this presupposes that such functionality exist within LabVIEW, the
> causes for crashes.
The shipping version of LV has the vast majority of debugging capabilities
removed -- to improve size and speed of the executable. A couple things to
eliminate. Are there any DLLs or CINs involved not written by NI? If so,
try to isolate them and either test them in isolation or eliminate them and
see if the crash still occurs. Once you are certain it is a problem with
an NI component, you can compare the versions of NI drivers on your machine
to the currently available versions.
Another thing to watch for. Has the system dialog ever indicated a module
name? The OS will often just list the EXE name, which doesn't help much
in determining which DLL or which part of the LV EXE accessed the bad
address, but sometimes it will list the DLL name. Also, do you ever get
a blue screen? On the blue screen, you will usually have a driver name,
and that can indicate which driver needs to be updated.
Finally, there is a decent chance this is caused by the code that LV
generates or the support library. If it is possible to send in a somewhat
simplified set of VIs that can reproduce the problem, then we can determine
what component is causing the problem and get it fixed faster.
Greg McKaskle
(3,682 Views)
Hi Greg,
There are no CINs or DLLs that are not from NI.
Today I manage to isolate the problem to NI-DAQ VIs, specifically I can have
it crash in Device Reset or AI Group Config. To find this I needed to
"instrument" the NI VIs, this means I placed outputdebugstring.VI in
sequence before and after each NI-DAQ VI call.
I'm using NI-DAQ 6.9.X with two 4452 and one 6711, the 4452s are RTSI
synchronised. I have removed the code that uses the 6711, so now I only have
the 4452 code. It is in these calls that I have the problem.
Machine A - PIII 500 MHz 128 MB
I have produced the problem under Windows NT 4 SP6 using NI-DAQ 6.9.0f9 (not
sure about the f9) with applications built using LabVIEW 5.1.1 and also
recompiled and tested with LabVIEW 6.0.3
Machine B - PIV 1300 MHz 256 MB
I have produced the problem under Windows 2000 SP2 using NI-DAQ 6.9.1f20
with applications built using LabVIEW 5.1.1 and also recompiled and tested
with LabVIEW 6.0.3
I can not ship the entire app to NI, so I have tried to isolate the problem,
which is why I needed to use things like outputdebugstring.vi and the
options debugging=true and memorychecking=true.
The problem is not totally reproducible, in that running the same code path
does NOT always generate an error. This makes me believe that there is a
timing/resource dependency that is hard to isolate. It took me more tries on
Machine B to get it to crash compared to Machine A.
The System Crash dialog does not indicate a DLL but the executable code for
the crash address, information from Dr Watson.
I hope this explains the problem a little better.
Any ideas?
Cheers
Peter
"Greg McKaskle" wrote in message
news:3B8DB6AE.FD0133BE@austin.rr.com...
run
> > on LV 6i.
allow
traces
function
has
the
there
> > causes for crashes.
to
and
machine
determine
> Greg McKaskle
(3,682 Views)
Hi Peter/Greg,
There has been mention of a couple of INI setting (debugging=true and
memorychecking=true ) that I'd like to get more information about. Are
these documented anywhere? Where can I get more information about these and
other INI settings?
Also, where is the fuction 'outputdebugstring.vi' located?
Thanks for your info.
Denis
(3,682 Views)
Hi Denis,
The INI settings are undocumented, but they are listed at Brian Renken's
site
http://labview.brianrenken.com/INI/undoc.shtm
These function may or may not be useful to you depending on your deeper
understanding of applications (such as memory handles).
out[putdebugString can be found on the NI web site iff you search for
"Outputting Debugging Strings on a PXI Controller"
this allows you to output strings to a debug terminal.
Happy debugging.
Cheers,
Peter
"Denis Jolivet" wrote in message
news:3b8f2dd9@newsgroups....
> Hi Peter/Greg,
and
> other INI settings?
> Denis
(3,682 Views)
