touch sensor multiplexor
I am trying to use the hitechnic touch sensor multiplexor with labview for Mindstorm Nxt 2011. I have found the VI for the multiplexor that labview comes with in the hitechnic additional sensor section, but it annoyingly only gives the output of all 4 touch sensors as a group of 4 results. I want to be able to manipulate each individual touch sensor as I would normally if the Mux wasnt being used. The program I have written initiates a sequence once a button is pressed, depending on which button is pressed would initiate a diffferent sequence. Now all I want to do is apply the same programming, but my buttons are now connected to the touch multiplexor, I would of thought there was a simple change in setting somewhere to allow this rather than have to do extra programming?
thanks
Tim
(2,976 Views)
Its fine, I found it 🙂
Tim
(2,975 Views)
Infact it seems what I found was the Sensor Multiplexor touch vi, and not the touch multiplexor. The sensor multiplexor touch button is exactly how I wish the touch multiplexor touch button to be but there isnt an option like that, all there is is the touch mux vi which gives the ouput of the 4 touch sensors in an array which is not what I want.
Any help?
Tim
(2,958 Views)
