touch screen capturing data frm hardware device
Hiiii
What labview real time module is require  to efficiently use a touch screen that can capture data every minute from a hardware device...
Thanks in advance....
(3,266 Views)
I think you do not need a real time system for data capture every minute ;). A touch panel running windows CE and labview should do the trick, and at the same time be stable enough. But if you need something rugged and stable perhaps a compactRIO is the right thing. https://www.ni.com/en/shop/compactrio.html But a RIO divice do no have a display.
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(3,251 Views)
Hi user_1,
Could you please identify what is an OS run on your touch screen, or it's just a touch screen attached to a PC so that I can guide you to a proper direction?
Regards, Kate
(3,226 Views)
Take a look at this document. https://www.ni.com/en/support/documentation/supplemental/08/requirements-for-desktop-pcs-as-phar-lap... it may help you some
(3,208 Views)
