total crash!
I've just finisched writing an application running perfectly under LV 5.1.
Then I've updated to LV 6.02.
Now, when executing the a.m. app (written under 5.1) my whole system
crashes (only ON/OFF of the PC is possible and it seems that it
also affects the proper function of Windows), when calling
individual (not all) sub_vi's.
NB: Mass compile has been executed already.
Any idea what I can do?
TIA Philipp
(2,905 Views)
"Philipp" schrieb im Newsbeitrag news:3b8371b5@newsgroups....
> Hi,
> TIA Philipp
on running the app the the crash will occur, when employing an array of
clusters.
If I want to edit this array in a diagram (i.e. not when running) the PC
will
crash as well.
Philipp
(2,905 Views)
"Philipp" wrote in message news:3b837ca7@newsgroups....
> > Hi,
5.1.
> > TIA Philipp
> Hi,
> clusters.
> will
> crash as well.
I had a problem with LV crashing that was related to an array of complicated
clusters. I was copying the array up to a custom control when LV crashed
and then I couldn't open the VI without LV crashing again. I ended up
deleting the custom control and that fixed it. Apparently it was corrupted.
After that I went without that control, because I guess it got too
complicated.
(2,905 Views)
Phillip,
Try making the array of clusters into a typedef.
No guarantees, but I don't know what else could cause that. I am sure that the LabVIEW developers do, now that you indicated the source of the problem.
(2,905 Views)
