tomography threedimensional
can i build a threedimensinal image with n planes that are the images of sections? I want to know if exist in LabView a function like "x,y intensity graph" but "x,y,z intensity graph" because i have a threedimensional matrix with all points, and i don't want to build image from matrix 2D or vector but from all points of 3D object. the attachements use Imaq Vision6 and LabView7. Thank.
(2,972 Views)
Hello -
In your attachment, it appears that the data you are trying to plot 3D is built into an array. What you need to do is extract elements from the array to create the necessary vector and matrix inputs. You can do this by using the Array Subset VI located on the Array subpalette on the Functions palette.
Let me know if this helps. Have a great day!
Becky B.
Becky Linton
Field Engineer
Office: 734-464-2463
Cell: 248-709-2822
Email: becky.linton@ni.com
(2,972 Views)
